D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/4/2009 2:28pm - 66 changes
Uplink Comparison Range: 03/04/2009 01:57P - 03/04/2009 02:28P
Channel Additions:
775 - AGAPY [MPEG2 SD] added to Anik F3 118.7W TP 19 ConUS beam (NA)
4205(205) - FXNWS [MPEG4 HD] added to Ciel-2 129W TP 28 ConUS beam (A) (H)
4205(205) - FXNWS [MPEG4 HD] added to EchoStar3 61.5W TP 27 ConUS beam (A) (H)
4206(206) - FOXB [MPEG4 HD] added to Ciel-2 129W TP 28 ConUS beam (A) (H)
4206(206) - FOXB [MPEG4 HD] added to EchoStar3 61.5W TP 27 ConUS beam (A) (H)
4287(387) - CI [MPEG4 HD] added to Ciel-2 129W TP 20 ConUS beam (A) (H)
4287(387) - CI [MPEG4 HD] added to Echostar12 61.5W TP 21 ConUS beam (A) (H)
5151(47) - WTEV [MPEG4 HD] added to EchoStar8 77W TP 05 ConUS beam (NA)(Jacksonville, FL-CBS)
5153(30) - WAWS [MPEG4 HD] added to EchoStar8 77W TP 05 ConUS beam (NA)(Jacksonville, FL-FOX)
5171(21) - WHP [MPEG4 HD] added to EchoStar8 77W TP 01 ConUS beam (NA)(Harrisburg, PA-CBS)
5180(49) - KTKA [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 8 beam (NA)(Topeka, KS-ABC)
5182(27) - KSNT [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 8 beam (NA)(Topeka, KS-NBC)
5183(43) - KTMJ [MPEG4 HD] added to Echostar12 61.5W TP 05 Area 8 beam (NA)(Topeka, KS-N/A)
5193(16) - KLRT [MPEG4 HD] added to EchoStar8 77W TP 09 ConUS beam (NA)(Little Rock, AR-FOX)
5260(19) - WHOI [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 22 (A) (H)(Peoria, IL-ABC)
5261(31) - WMBD [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 22 (A) (H)(Peoria, IL-CBS)
5262(25) - WEEK [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 22 (A) (H)(Peoria, IL-NBC)
5263(43) - WYZZ [MPEG4 HD] added to Ciel-2 129W TP 15 Spotbeam 22 (A) (H)(Bloomington, IL-FOX)
8119(43) - WSAH [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 04 (NA)(Bridgeport, CT-IND)
8119(43) - WSAH [MPEG4 SD] added to Echostar12 61.5W TP 15 Area 6 beam (NA)(Bridgeport, CT-IND)
8166(40) - WMGM [MPEG2 SD] added to EchoStar10 110W TP 26 Spotbeam 04 (NA)(Wildwood, NJ-NBC)
8166(40) - WMGM [MPEG4 SD] added to Echostar12 61.5W TP 11 Area 5 beam (NA)(Wildwood, NJ-NBC)
Channel Removals:
595 - TVCI (A) removed from EchoStar3 61.5W TP 18 ConUS beam
616 - PTV (A) removed from EchoStar3 61.5W TP 18 ConUS beam
622 - APUNJ (A) removed from EchoStar3 61.5W TP 18 ConUS beam
902 - GEONW (A) removed from EchoStar3 61.5W TP 18 ConUS beam
6101 - PTV (A) (H) removed from EchoStar3 61.5W TP 08 ConUS beam
6104 - APUNJ (A) (H) removed from EchoStar3 61.5W TP 10 ConUS beam
6110 - GEONW (A) (H) removed from EchoStar3 61.5W TP 12 ConUS beam
6112 - TVCI (A) (H) removed from EchoStar3 61.5W TP 14 ConUS beam
7165 - WPTY (NA) removed from Echostar12 61.5W TP 05 Area 9 beam(Memphis, TN-ABC)
7281 - WISC (NA) removed from Echostar12 61.5W TP 05 Area 4 beam(Madison, WI-CBS)
8351 - WKRC (NA) removed from EchoStar8 77W TP 04 ConUS beam(Cincinnati, OH-CBS)
8988 - KWKT (NA) removed from Echostar12 61.5W TP 11 Area 3 beam(Waco, TX-FOX)
Channel Moves:
4800 - TMP30 [MPEG4 HD] moved from EchoStar11 110W TP 07 ConUS beam to Ciel-2 129W TP 18 ConUS beam (NA)
4801 - TMP31 [MPEG4 HD] moved from EchoStar11 110W TP 13 ConUS beam to Ciel-2 129W TP 18 ConUS beam (NA)
4802 - TMP32 [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to Ciel-2 129W TP 32 ConUS beam (NA)
7025 - KXVA [MPEG2 SD] moved from EchoStar1 148W TP 31 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(Abilene, TX-FOX)
7063 - KIDY [MPEG2 SD] moved from EchoStar1 148W TP 15 ConUS beam to EchoStar1 148W TP 03 ConUS beam (A) (H)(San Angelo, TX-FOX)
Channel Package Flag Changes:
205 - FXNWS [MPEG2 SD] - EchoStar7 119W TP 06 ConUS beam changed package flags (A)
205 - FXNWS [MPEG4 SD] - Echostar6 72.7W TP 03 ConUS beam changed package flags (A)
574 - NDTV [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
574 - NDTV [MPEG2 SD] - EchoStar3 61.5W TP 08 ConUS beam changed package flags (A)
585 - AAJTK [MPEG2 SD] - EchoStar1 148W TP 25 ConUS beam changed package flags (A)
585 - AAJTK [MPEG2 SD] - EchoStar3 61.5W TP 12 ConUS beam changed package flags (A)
794 - AAJTK [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed package flags (A)
5250(13) - KRDO [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 28 changed to Available (H)(Colorado Springs, CO-ABC)
5251(11) - KKTV [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 28 changed to Available (H)(Colorado Springs, CO-CBS)
5252(5) - KOAA [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 28 changed to Available (H)(Pueblo, CO-NBC)
5253(21) - KXRM [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 28 changed to Available (H)(Colorado Springs, CO-FOX)
5250(13) - KTNV [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 27 changed to Available (H)(Las Vegas, NV-ABC)
5251(8) - KLAS [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 27 changed to Available (H)(Las Vegas, NV-N/A)
5252(3) - KVBC [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 27 changed to Available (H)(Las Vegas, NV-NBC)
5253(5) - KVVU [MPEG4 HD] - Ciel-2 129W TP 14 Spotbeam 27 changed to Available (H)(Henderson, NV-FOX)
5260(8) - KOLO [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 17 changed to Available (H)(Reno, NV-ABC)
5261(2) - KTVN [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 17 changed to Available (H)(Reno, NV-CBS)
5262(4) - KRNV [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 17 changed to Available (H)(Reno, NV-NBC)
5263(11) - KRXI [MPEG4 HD] - Ciel-2 129W TP 02 Spotbeam 17 changed to Available (H)(Reno, NV-FOX)
5250(6) - KIVI [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 11 changed to Available (H)(Nampa, ID-N/A)
5252(7) - KTVB [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 11 changed to Available (H)(Boise, ID-NBC)
5253(12) - KTRV [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 11 changed to Available (H)(Nampa, ID-FOX)
5261(4) - KGBT [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 52 changed to Available (H)(Harlingen, TX-CBS)
5262(23) - KVEO [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 52 changed to Available (H)(Brownsville, TX-NBC)
7524(26) - KTEND [MPEG2 SD] - EchoStar10 110W TP 20 Spotbeam 21 changed to Available (H)(Ada, OK-NBC)
7524(26) - KTEND [MPEG4 SD] - Echostar12 61.5W TP 01 Area 3 beam changed to Available (H)(Ada, OK-NBC)
19214 - HISAP [DATA] - EchoStar7 119W TP 02 ConUS beam changed package flags (A)
Channels in the system: 6508
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Additions:
Channel Removals:
Channel Moves:
