3/25/2010 3:20am - Uplink Activity Report - 83 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/25/2010 3:20am - 83 changes
Uplink Comparison Range: 03/25/2010 03:05A - 03/25/2010 03:20A
Channel Additions:
6883 - UP11 [MPEG4 HD] added to EchoStar8 77W TP 29 ConUS beam (NA)
6884 - UP11 [MPEG4 HD] added to EchoStar8 77W TP 28 ConUS beam (NA)
Channel Moves:
103 - MOVIE [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
104 - IDEA [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
120 - HIST [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
124 - BET [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
129 - BRAVO [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
134 - SHNBC [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
137 - QVC [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
140 - ESPN [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
141 - ESPNU [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
142 - ESNWS [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
143 - ESPCL [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
144 - ESPN2 [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
158 - FUSE [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
161 - MTV2 [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
180 - ABCFM [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
184 - APL [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
204 - TRU [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
210 - CSPAN [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
211 - CSPN2 [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
213 - NASA [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
222 - HSN [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
225 - C&T [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
228 - SHNBC [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
230 - ICTV [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
260 - TBN [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
261 - EWTN [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
270 - UNVSN [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
273 - GLVSN [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
299 - REELZ [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
300 - HBO-E [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
302 - HBOSG [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
327 - TMC-E [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
328 - TMCXE [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
414 - FOXRM [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A) (H)
469 - ORDER [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
488 - PLBY [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
489 - PLBY [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
494 - JUICY [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
502 - MOVIE [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
827 - UNVSN [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
833 - GLVSN [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
880 - BRAVO [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
887 - APL [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
925 - AUD03 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A) (H)
934 - AUD11 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A) (H)
938 - AUD15 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A) (H)
945 - AUD18 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A) (H)
956 - CD 7 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
957 - CD 8 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
958 - CD 9 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
960 - CD 11 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
971 - CD 22 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
972 - CD 23 [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
5836 - TST [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (NA)
5898 - DRMT2 [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (NA)
5899 - DRMT3 [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (NA)
6002 - SIRI [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
6003 - SIRI [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
6005 - SIRI [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
6006 - SIRI [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
6007 - SIRI [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
6012 - SIRI [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
6013 - SIRI [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
6025 - SIRI [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
6076 - SIRI [MPEG AUDIO] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
6812 - UP4 [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 02 ConUS beam (NA)
9404 - CSPAN [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A) (H)
9409 - TBN [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A) (H)
9411 - NAUHS [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A) (H)
9412 - UCTV [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A) (H)
9417 - EWTN [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A) (H)
9602 - BTV [SD TV] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
9648 - IDEA [MPEG2 SD] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
19067 - ESPNI [DATA] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
19073 - HSNAP [DATA] moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
36701 - MTDTA [EPG] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 02 ConUS beam (A)
Transponder Changes:
EchoStar7 119W TP 02 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
EchoStar7 119W TP 04 ConUS beam changed from 20000 QPSK 5/6 to 20000 QPSK 7/8
EchoStar7 119W TP 10 ConUS beam changed from 21500 8PSK 2/3 to 20000 QPSK 5/6
EchoStar7 119W TP 11 ConUS beam changed from 20000 QPSK 7/8 to 20000 QPSK 5/6
EchoStar8 77W TP 28 ConUS beam 22500 QPSK TURBO CODED 5/6 added
Channels in the system: 6902
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.03.12
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
Yep! I don't see the point in swapping 11 for 4 though...but then again I don't know how they have to configure things there to swap over to E14.
Yes this is confusing because TP 4 is a spotbeam TP on E-14 that is suppose to be used right away.
It's either technical on their side that we don't see... or it's obvious one. Look at the channels they moved into TP4. Probably not too many people would be crying about those channels going Off Air for an hour late one night. The channels that on TP11 now, I could see people flipping out about some of those. So they just moved the "less impact" channels to TP4.
D
3/24/2010 3:15pm - Uplink Activity Report - 7 changes
D
3/26/2010 6:27am - Uplink Activity Report - 1 change
Similar threads
D
Replies
Views
3K
D
D
Replies
Views
3K
D
