SatelliteGuys.US DishNetwork Uplink Report - 3/10/2016 17:15 - 36 Changes
Uplink Comparison Range: 3/07/2016 05:31 - 3/10/2016 17:15 (PST)
Channel Additions:
125 - FXX [MPEG2 SD] added to EchoStar11 110W TP 11 ConUS (FXX)(A)
149 - FOXS2 [MPEG4 SD] added to Echostar16 61.5W TP 17 Conus (FOXS2)(A)
149 - FOXS2 [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS (FOXS2)(A)
7660(61) - PBS [MPEG2 SD] added to EchoStar14 119W TP 08 ConUS (Mkt: Harlingen,TX (USA-PBS))(NA)(H)
9850 - LA7TE [MPEG2 SD] added to Anik F3 118.7W TP 12 ConUS (LA7TE)(NA)(H)
Channel Removals:
125 - INFO [MPEG2 SD] (NA)(H) removed from EchoStar14 119W TP 12 ConUS (Dish Network Information Channel)
6566(2) - LOCAL [MPEG2 SD] (A)(H) removed from Ciel-2 129W TP 15 Spotbeam 10 (LOCAL)(Mkt: Bend,OR)
7127(2) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar10 110W TP 18 Spotbeam 40 (LOCAL)(Mkt: Missoula,MT)
7188(2) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar14 119W TP 01 Spotbeam B2 (LOCAL)(Mkt: Eugene,OR)
8625(2) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar10 110W TP 12 Spotbeam 45 (LOCAL)(Mkt: Seattle,WA)
9181(23) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar10 110W TP 18 Spotbeam 40 (LOCAL)(Mkt: Spokane,WA)
9375(3) - LOCAL [MPEG2 SD] (A)(H) removed from EchoStar10 110W TP 12 Spotbeam 45 (LOCAL)(Mkt: Yakima,WA)
MAP Changed:
4149(240) - FXX [MPEG4 HD] Nimiq5 72.7W TP 06 ConUS map changed to (125) (FXX)(A)(H)
4149(240) - FXX [MPEG4 HD] EchoStar11 110W TP 22 ConUS map changed to (125) (FXX)(A)(H)
4943(240) - FXX [MPEG4 HD] EchoStar14 119W TP 01 Spotbeam B22 map changed to (125) (FXX)(A)(H)
5034(240) - FXX [MPEG4 HD] EchoStar14 119W TP 01 Spotbeam B22 map changed to (125) (FXX)(A)(H)
5306(240) - FXX [MPEG4 HD] Nimiq5 72.7W TP 06 ConUS map changed to (125) (FXX)(A)(H)
5306(240) - FXX [MPEG4 HD] EchoStar11 110W TP 22 ConUS map changed to (125) (FXX)(A)(H)
5560(240) - FXX [MPEG4 HD] EchoStar11 110W TP 22 ConUS map changed to (125) (FXX)(A)(H)
9520(240) - FXX [MPEG4 HD] Nimiq5 72.7W TP 06 ConUS map changed to (125) (FXX)(A)
9520(240) - FXX [MPEG4 HD] EchoStar11 110W TP 22 ConUS map changed to (125) (FXX)(A)
9613(397) - FOXS2 [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS map changed to (149) (FOXS2)(A)(H)
9613(397) - FOXS2 [MPEG4 HD] Ciel-2 129W TP 19 ConUS map changed to (149) (FOXS2)(A)(H)
Tier Changed:
125 - INFO [MPEG4 SD] Echostar16 61.5W TP 12 Conus renamed to FXX , moved to Echostar16 61.5W TP 17 Conus , changed to Available , changed to Visible (FXX)(A)
9426(154) - NFL [MPEG4 HD] Nimiq5 72.7W TP 13 ConUS changed to (NFL Network)(A)(H)
9426(154) - NFL [MPEG4 HD] Ciel-2 129W TP 30 ConUS changed to (NFL Network)(A)(H)
9434(152) - MLBN [MPEG4 HD] Nimiq5 72.7W TP 26 ConUS changed to (MLBN)(A)(H)
9434(152) - MLBN [MPEG4 HD] Ciel-2 129W TP 18 ConUS changed to (MLBN)(A)(H)
9466(159) - NBCSP [MPEG4 HD] Nimiq5 72.7W TP 17 ConUS changed to (NBCSP)(A)(H)
9466(159) - NBCSP [MPEG4 HD] Ciel-2 129W TP 22 ConUS changed to (NBCSP)(A)(H)
9469(369) - MTVL [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS changed to (MTVL)(A)(H)
9469(369) - MTVL [MPEG4 HD] Ciel-2 129W TP 19 ConUS changed to (MTVL)(A)(H)
9505(340) - ENCOR [MPEG4 HD] Nimiq5 72.7W TP 04 ConUS changed to (Encore (East))(A)(H)
9505(340) - ENCOR [MPEG4 HD] EchoStar11 110W TP 19 ConUS changed to (Encore (East))(A)(H)
Channel Moves:
5437(437) - FOXSE [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS moved to Echostar16 61.5W TP 05 Conus (FOXSE)(A)(H)
Name Changed:
9901 - AMDIA [MPEG2 SD] Anik F3 118.7W TP 07 ConUS renamed to INFO (Dish Network Information Channel)(A)(H)
Transponder Changes:
EchoStar14 119W TP 08 ConUS (21.500 8PSK 2/3) added.
Anik F3 118.7W TP 12 ConUS (20.000 QPSK 3/4) added.
EchoStar14 119W TP 07 ConUS (21.500 8PSK 2/3) removed.
Echostar16 61.5W TP 12 Conus (21.500 8PSK 2/3) removed.
EchoStar10 110W TP 12 Spotbeam 45 (20.000 QPSK 5/6) removed.
EchoStar10 110W TP 18 Spotbeam 40 (20.000 QPSK 5/6) removed.
Ciel-2 129W TP 15 Spotbeam 10 (20.000 QPSK 5/6) removed.
EchoStar14 119W TP 01 Spotbeam B2 (20.000 QPSK 7/8) removed.
Channels in the system: 9782
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Additions:
Channel Removals:
MAP Changed:
Tier Changed:
Channel Moves:
Name Changed:
(FP) = Free Preview
