I have TWO brand new in the box Titanium CK12 Dual C/KU Band LNBF's that I bought back when I was planning on putting up an 8 to 10 foot C-Band satellite. Unfortunately the geography of my yard/neighborhood has ruled that option out so I don't have a use for them now and would like to pass them on to someone who can use them.
I'm asking $60 including shipping to your location. I paid $55 for each of them and I seriously doubt shipping will only cost $5, so I'm still losing $$. I am willing to entertain offers if someone wants to buy both though.
Here are the specs from Brian's website on them:
The CK1S DRO C/KU LNBF Kit includes:
Input Frequency Range C: 3.40 ~ 4.20GHz
KU: 11.7 ~ 4.20GHz
Output Frequency Range C: 950 ~ 1450MHz
KU: 950 ~ 2000MHz
L.O. Frequency C: 5150MHz
KU: 10750MHz
Noise Temperature C: 17K typical
KU: 0.5dB typical
LO Stability
C: ±1.0 MHz [max] @ +77°F (25°C)
± 2.0Mhz [max] @ -22°F~+140°F (-30°C~+60°)
KU: ±50KHz[max] @ -22°F~+140°F (-30°C~+60°)
LO Phase Noise @ 1Khz -65dBc
LO Phase Noise @ 10Khz -80dBc
LO Phase Noise @ 100Khz -95dBc
Conversion Gain 65dB typical
Gain Flatness ±4dB
Gain Variation ±1dB / 27 MHz
Image Rejection -45dB
Cross Polarization Isolation 20dB typical
Control Signals Ca [V/CR] 11.5 ? 14.0V
Control Signals Cb [ H/CL] 16.0 ? 20.0V
DC Voltage 11 ~ 20Vdc
Current C: 130mA [max]
KU: 90mA [max]
Output VSWR 2.2 : 1 typical
Temperature Range -20 ~ +140°F / -40 ~ +60°C
Relative Humidity 0 ?100% condensing
Polarization Type Linear (w/dielectric for C-band circular)
Output Impedance 75?
Connection F-Type Female 2x
Weight 14.3oz / 540g
Construction Cast Aluminum
Hardware Zinc Allen Head (w/tool)
Housing / Scalar Finish Polyurethane Powder (chip resistant)
Feedhorn Cover RF Low-loss (blue color)
Dimensions (w/o scalar) 10 1/2 (l) x 3 1/2 (h) x 2 3/4 (w) in
270 (l) x 85 (h) x 68 (w) mm
Scalar Type * Flat - Prime Focus, 3 Ring
F/D with included Flat Scalar 0.32 ? .44+ (cast scale)
Mount Type with Flat Scalar Single pole, Tripod or Quad legs
* Optional Conical Scalar Kit SC1 Offset Type Dish with F/D .5 ? .8
- One C-band Output - Wideband 3.4 - 4.2GHz - LO 5150
- One KU-band Output - 11.7 - 12.75GHz Standard LO 10750
- C-band DRO type of local oscillator
- KU-band PLL type of local oscillator
- Two Year Warranty
- Prime Focus Flat Scalar suitable for mounting on 3 or 4 leg feedhorn support arms or buttonhook design
- Zinc Coated Allen Head screws for feedhorn and scalar mounting
- Dielectric Slab insert for C-band circular polarity reception.
- Hex Tool
KU: 11.7 ~ 4.20GHz
KU: 950 ~ 2000MHz
KU: 10750MHz
KU: 0.5dB typical
LO Stability
Gain Flatness ±4dB
KU: 90mA [max]
