Just purchased the Direct TV Hughes DVR-80 receiver yesterday at Best Buy and yes I now know that I have to run TWO lines into the back of the receiver to get full functionality of the Tivo/DVR service (ie. taping two things at once). I have a triple LNB receiver with 3 receivers in the house, therefore since the triple LNB satellite has a built in multiswitch with 4 ports, I have one that is not currently occupied.
Here is my problem. The sattelite is located on the very opposite corner of where my other cables enter the house and are grounded. The TV that I want to go is literally 8 feet from my sattelite just inside the outside portion of the house where the sat. is. My other cables are buried going to the other side of the house and I would rather just drill into the side of the house right by the satellite to feed this second cable to the receiver. Question is can I just run it into the house and into the receiver or do I have to run it all the way to the othe side of the house, ground it and then run it all the way back for my second line? This delimma really comes down to grounding. Do I need to ground this additional line? If so, can I ground it independantly from the other line and not have to run cable all the way over just to ground? I have a huge steel support beam that goes across the house just inside the crawl space right by the satellite, it would be cool if I could just attach to it if I need to ground this second line or I guess I could put a grounding rod in. The easy way would be to just run the cable into the house right there and not ground it, but I'm afraid of the issues. I need some advice please.
