The following works perfect:
Now I replace the manual switch with a DMSI SW-21K. Coax 2 (22K tone ON) now works fine but coax 1 (tone OFF) does not respond on any of the ports from the diseqc switch. There is signal, but no quality at all.
Pondering possibilities - inserting the 22K switch attenuates the signal more than the manual switch, or perhaps the 22K is not passing diseqc commands up the line? If the latter then I would expect at least port 1 to work, but it does not.
Is this theoretically a legal position for a 22K switch?
Code:
receiver - manual switch - coax 1 - DMSI diseqc to 4 standard lnbs
- coax 2 - BSC621-2 (only using C-Band side)
