You cannot. There is no way to connect an OTA to that particular 211. You would need to find a 211K.Where can you buy a OTA antenna adapter for a 211z?
Doesn't the Z allow usage of the OTA adapter dongle, same as used for the Wally?You cannot. There is no way to connect an OTA to that particular 211. You would need to find a 211K.
No, not that I ever heard ofDoesn't the Z allow usage of the OTA adapter dongle, same as used for the Wally?
Pattykay doesn't post here any longer.Interesting. According to the 211z literature, an OTA adaptor was available. But the part number provided is the same as a Wally adaptor, which say aren't compatible with the 211 series. Maybe user pattykay has some insight on this.
I was thinking that, too.I think the single tuner adapter might have worked but doesn't seem to be available any longer.
Does your first party model or an Air TV model work with the OTA ?I can attest that the modern dual tuner OTA adapter (the one with the non detachable usb cord) does not work on a 211z. I have both a first party model (black) and an AirTV model (white). I don’t have a single tuner adapter, but it is also my understanding that that’s the only model to work on a 211z, if at all.
The Air TV model is the same as the Dish 2 tuner model so, no, it won't work.Does your first party model or an Air TV model work with the OTA ?
