I have a question that doesn't apply to your feed alignment tool. I recently picked up a 12 foot Unimesh dish. Sunday, I put it on the pole and replaced the old feed assembly with a Titanium dual output LNBF. The Dish was moved in one piece and it was located about 5 miles from my location as the crow flies. I installed a motor arm and moved the dish up and down in very small increments, and wasn't able to acquire a signal. I used a receiver that had already been tuned in on one of my other dishes.
Last evening, I took off the Titanium and installed a 25K LNBF I had left over from the old C-Band days. I again swept the dish and located a signal on the Grit MUX on Galaxy 19. I tweaked and tuned on the dish for the better part of an hour, and the best I could get was 71% on the signal quality. I was a bit surprised that I got the same quality on this 12 footer and I have on my 7 1/2 footer. Since it had been in operation at the old location, I just assumed the elevation bar and offset angle was right.
Do you have any idea what the signal level should be in order to receive the MPEG 4 HD channels on this satellite. I have not tried to readjust the elevation and offset at this point. Those adjustments are pretty rusty as this dish sat in a meadow just off the river bank. Any suggestions? BTW, let me know when you get the polarity tool finished, I'd like one.
