110
I've got the 110 on a separate dish. As mentioned, the 613 screen shows a big red x on 110...item B shows 242/108. We had some high winds last night. I'll get up tomorrow and check to see if it's secure. Is it just a process of elimination...alignment, cables-connectors or lnb? or would a bad lnb show up in the check switch test. Thanks.
Use a sharpie to mark the dish when you have it aligned properly, will make it fast to realign in the future.
I use the sharpie method. I have an under eve mount because our roof is metal. We commonly have high winds and with the design of the mount I have to adjust and tighten a couple of times a year.
Hopper with built in sling? or sling adaptor?
remote control help
