Hello All
Just wondering if this Mux still active.
Let me know.
Thanks in Advance.
Regards.
Chewie
Let me know.
Thanks in Advance.
Regards.
Chewie
Hello All
Let me know.
Thanks in Advance.
Regards.
Chewie
Hello All
Let me know.
Thanks in Advance.
Regards.
Chewie
It can be hit or miss though Chewie...you really need to be perfectly aimed
The MK-1 is a standard LNBF and uses a LO of 10750 the universal LNBF uses a different dual LO of 9750-10600. You need to change the LNB settings in the receiver menu when you change the LNB type. Since the Universal LNB has a built in 22khz switch the 22khz setting will be auto or greyed out in the LNB menu when you set the LO to 9750-10600.I change the LNB to a Universal LNB and is not getting it, I was getting them with the MK -1 lnb.
I might have to go back to it.
