1000.4 Help
Chavez
185
Milky Way
I have a 722 and decided to try a 1000.4 western arc, I get everything set up (the pole is plumb). I bring in 119 with good signal, check switch and only 119 but it is in the third box? Ok, so I move the dish east 9 degrees, check switch 110 in the third box? Any suggestions?
Missing some important info, first are you using a switch of any kind? Second what are the skew and elevation settings on your dish?
Ok...I got 119 into box 1, has a signal level of about 74, but xx in the last two boxes. I mounted the dish in the same spot that I had my 1000.2.
That did it...I double checked the manual the dish came with and it has a skew of 65...must be a misprint in their book...thanks for the help!!
Problem with Dish Remote Access
612 system update
