D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 10/22/2009 2:11am - 85 changes
Uplink Comparison Range: 10/22/2009 01:55A - 10/22/2009 02:11A
Channel Additions:
36610 - ACTVT [161] added to Nimiq5 72.7W TP 21 ConUS beam (A)
Channel Removals:
6085 - HISTI (NA) removed from EchoStar11 110W TP 01 ConUS beam
6085 - HISTI (NA) removed from Nimiq5 72.7W TP 11 ConUS beam
6086 - BIO (NA) removed from EchoStar11 110W TP 05 ConUS beam
6086 - BIO (NA) removed from Nimiq5 72.7W TP 03 ConUS beam
6087 - BIO (NA) removed from Ciel-2 129W TP 29 ConUS beam
6087 - BIO (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
6088 - HMC (NA) removed from EchoStar11 110W TP 01 ConUS beam
6088 - HMC (NA) removed from Nimiq5 72.7W TP 01 ConUS beam
6089 - HMC (NA) removed from Ciel-2 129W TP 29 ConUS beam
6089 - HMC (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
6090 - ID (NA) removed from EchoStar11 110W TP 09 ConUS beam
6090 - ID (NA) removed from Nimiq5 72.7W TP 03 ConUS beam
6091 - VS. (NA) removed from EchoStar11 110W TP 21 ConUS beam
6091 - VS. (NA) removed from Nimiq5 72.7W TP 05 ConUS beam
6092 - VS. (NA) removed from Ciel-2 129W TP 29 ConUS beam
6092 - VS. (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
6093 - GAC (NA) removed from EchoStar11 110W TP 11 ConUS beam
6093 - GAC (NA) removed from Nimiq5 72.7W TP 05 ConUS beam
6094 - FUSE (NA) removed from EchoStar7 119W TP 02 ConUS beam
6094 - FUSE (NA) removed from Nimiq5 72.7W TP 05 ConUS beam
6095 - WE (NA) removed from EchoStar7 119W TP 12 ConUS beam
6095 - WE (NA) removed from Nimiq5 72.7W TP 15 ConUS beam
6096 - IFC (NA) removed from EchoStar7 119W TP 06 ConUS beam
6096 - IFC (NA) removed from Nimiq5 72.7W TP 15 ConUS beam
6097 - CI (NA) removed from EchoStar11 110W TP 19 ConUS beam
6097 - CI (NA) removed from EchoStar8 77W TP 13 ConUS beam
6098 - AMC (NA) removed from EchoStar7 119W TP 08 ConUS beam
6098 - AMC (NA) removed from Nimiq5 72.7W TP 09 ConUS beam
6099 - LMN (NA) removed from EchoStar11 110W TP 02 ConUS beam
6099 - LMN (NA) removed from Nimiq5 72.7W TP 09 ConUS beam
6100 - LMN (NA) removed from Ciel-2 129W TP 23 ConUS beam
6100 - LMN (NA) removed from EchoStar3 61.5W TP 20 ConUS beam
Channel Moves:
119 - BIO [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
173 - DISW [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
192 - ID [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
204 - TRU [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
205 - FXNWS [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
207 - CNBCW [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
209 - MSNBC [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
261 - EWTN [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A)
302 - HBOSG [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A)
304 - HBO2W [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A)
311 - MAX-W [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
329 - TMC-W [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
330 - TMCXW [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
340 - ENCOR [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
351 - STRZW [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
387 - CI [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
401 - GOLF [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
409 - CSNCA [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A) (H)
411 - PRIME [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A) (H)
437 - SPSOU [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A) (H)
546 - HDPPV [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
547 - HDPPV [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
548 - HDPPV [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
549 - HDPPV [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
4152 - CBS C [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
4194 - GREEN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
4239 - WGN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
4287 - CI [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
5327 - WGN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
9417 - EWTN [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A) (H)
9446 - WGN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
9457 - GREEN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
9465 - MAVHD [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
9481 - TMC-E [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
9495 - CBS C [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
9496 - SEDGE [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 13 ConUS beam (A) (H)
9498 - STRZW [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 13 ConUS beam (A) (H)
9505 - ENCOR [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 13 ConUS beam (A) (H)
9531 - DNFYI [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
Transponder Changes:
Nimiq5 72.7W TP 03 ConUS beam 20000 QPSK 5/6 removed
Nimiq5 72.7W TP 05 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 11 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 13 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 15 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 17 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 19 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 23 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 25 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 27 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 29 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 31 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
EchoStar8 77W TP 32 ConUS beam 20000 QPSK 5/6 removed
Channels in the system: 6608
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Additions:
Channel Removals:
Channel Moves:
