1/7/2010 7:44pm - Uplink Activity Report - 26 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 1/7/2010 7:44pm - 26 changes
Uplink Comparison Range: 01/07/2010 07:28P - 01/07/2010 07:44P
Channel Additions:
6802 - UP2 [MPEG2 SD] added to EchoStar3 61.5W TP 18 ConUS beam (NA)
Channel Moves:
471 - SPORT [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A)
575 - SAB [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
596 - GLOBO [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
597 - RCORD [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
605 - ANTEN [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
608 - ITVN [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A) (H)
612 - SETMX [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A)
614 - SET [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
618 - B4UMU [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
619 - B4U [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
624 - SHARA [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
640 - TVJPN [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A)
642 - ART [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
646 - ESC-1 [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
647 - NILE [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
649 - DUBAI [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
665 - ZIKR [MPEG AUDIO] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
669 - ARTMU [MPEG AUDIO] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
671 - MLODY [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
673 - MZIKA [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A)
767 - ABUDA [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A)
776 - ALARA [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A)
782 - IQRAA [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 29 ConUS beam (A) (H)
911 - ANTRA [MPEG AUDIO] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
9620 - BTV [SD TV] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A)
Channels in the system: 6648
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
TP18 Fail on E3? Or did they just cear it off for some other reason?
I don't think this was scheduled at all! Anyone have a dish pointed at 61.5? TP18 is in the transponder tables still due to the UP channel holder. It might not lock if they switched it to 8PSK though since it is listed as QPSK. I'm not going to swing over my 91 to 61.5...too damn cold outside...almost freezing with high winds and humidity..I'll pass with the temp, humidity, and wind combination.
I get DisneyHD off of 61.5 and its not coming in. That's my wing dish so hopefully overnight tonight it'll pick it up off of the Western Arc. Not gonna do a reset with the game on!
I subscribe to channel 596 - and definitively there was smthing going on, as the channel was down for about 1:30hrs until around 8:45pm ET - +- the time digiblur auto-job posted the channel moves - and, until around that time, I was getting a msg indicating couldn't lock the 61.5 tp 18.
Disney HD is working for me, it's on transponder 25.
Just ran through those transponders on the Point Dish page. 17 and 18 show nothing. The adjacent transponders appear normal so far as I remember.
Thanks for the update... with what you said I'd say something happened to transponder 18.
Aw come on, you big girl!
I mounted my 1000.4 last year in -10F temps using slingplayer on my Windows Mobile phone to point it via the Point Dish screen.
I'm also seeing 0 signal on 18.
I've tried the mounting of the dish via slingplayer....now that's a pain. I'll take the temps in north over this junk anyday. People thought I was nuts walking around in the 20's with a light jacket when I was up north last year. They kept telling me "the southerner is going to freeze" when they were outside wearing huge coats. But I do admin I'd rather this weather than 100 degrees and 98% humidity with zero wind. You sweat just looking out the window from the couch.
Yeah. -20F and the condensation is on the inside of the windows, then in the summer with 90% humidity the condensation is on the outside. Can't win. Still happy to be living in a time when we've mastered HVAC.
Hang in there E*3, the cavalry is going to take some time getting there to relieve you of your post.:no
Interesting that shortly before this uplink was posted, I lost signal on ESPN2 HD from EA for about a minute or two. Thought it was something on my end, but maybe something related to this change?
it doesnt show that channel moving so probably not
Looks like it was a TP that held International channels
Taking a shower when not even in the bathtub. Ouch!!!!
D
1/4/2010 3:49pm - Uplink Activity Report - 14 changes
D
1/6/2010 4:45pm - Uplink Activity Report - 87 changes
Similar threads
D
Replies
Views
2K
D
D
Replies
Views
2K
D
