1/30/2011 9:14am - Uplink Activity Report - 68 changes
  • Thread starter DigiDish Uplink Report
  • Start date
  • Replies 0
  • Views 2K
D
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 1/30/2011 9:14am - 68 changes
Uplink Comparison Range: 01/30/2011 08:59A - 01/30/2011 09:13A
Channel Additions:
6801 - UPSD [MPEG2 SD] added to EchoStar8 77W TP 24 ConUS beam (Virtual Channel) (NA)
6803 - UP3 [MPEG2 SD] added to EchoStar8 77W TP 17 ConUS beam (Virtual Channel) (NA)
6805 - UP4 [MPEG2 SD] added to EchoStar8 77W TP 02 ConUS beam (Virtual Channel) (NA)
6813 - UP4 [MPEG2 SD] added to EchoStar8 77W TP 08 ConUS beam (Virtual Channel) (NA)
Channel Removals:
4810 - TMP40 (NA) [MPEG AUDIO] removed from Echostar15 61.5W TP 23 ConUS beam
4816 - TMP46 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4820 - TMP50 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4825 - TMP26 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4826 - TMP56 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4827 - TMP57 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4835 - TMP69 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4836 - TMP66 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4837 - TMP67 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4838 - TMP68 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4839 - TMP71 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4840 - TMP72 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4870 - TP211 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4871 - TP212 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4872 - TP213 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4873 - TP214 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
4874 - TP215 (NA) [MPEG2 SD] removed from Echostar15 61.5W TP 23 ConUS beam
Channel Moves:
9357 - KVTN [MPEG4 SD] moved from EchoStar8 77W TP 17 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Mkt:Little Rock, AR-Pine Bluff, AR-REL) (A) (H)
9055 - WAWSD [MPEG4 SD] moved from EchoStar8 77W TP 17 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Mkt:Jacksonville, FL-Jacksonville, FL-MY) (A) (H)
8873 - WJAN [MPEG4 SD] moved from EchoStar8 77W TP 08 ConUS beam to Echostar15 61.5W TP 23 ConUS beam (Mkt:West Palm Beach, FL-Miami, FL-IND) (A) (H)
5150 - WTVQ [MPEG4 HD] moved from EchoStar8 77W TP 20 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Lexington, KY-Lexington, KY-ABC) (A) (H)
5151 - WKYT [MPEG4 HD] moved from EchoStar8 77W TP 20 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Lexington, KY-Lexington, KY-CBS) (A) (H)
5152 - WLEX [MPEG4 HD] moved from EchoStar8 77W TP 20 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Lexington, KY-Lexington, KY-NBC) (A) (H)
5153 - WDKY [MPEG4 HD] moved from EchoStar8 77W TP 20 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Lexington, KY-Danville, KY-FOX) (A) (H)
9211 - WKLE [MPEG4 SD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Lexington, KY-Lexington, KY-PBS) (A) (H)
9212 - WLJC [MPEG4 SD] moved from EchoStar8 77W TP 20 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Lexington, KY-Beattyville, KY-REL) (A) (H)
5170 - WHAS [MPEG4 HD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-ABC) (A) (H)
5171 - WLKY [MPEG4 HD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-CBS) (A) (H)
5172 - WAVE [MPEG4 HD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-NBC) (A) (H)
5173 - WDRB [MPEG4 HD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-FOX) (A) (H)
9099 - WBKI [MPEG4 SD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Louisville, KY-Campbellsville, KY-CW) (A) (H)
9100 - WMYO [MPEG4 SD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Louisville, KY-Salem, IN-MY) (A) (H)
9101 - WKPC [MPEG4 SD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-PBS) (A) (H)
9102 - WKMJ [MPEG4 SD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-PBS) (A) (H)
9261 - WKPD [MPEG4 SD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Paducah, KY-Paducah, KY-PBS) (A) (H)
9263 - WQWQ [MPEG4 SD] moved from EchoStar8 77W TP 24 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Mkt:Paducah, KY) (A) (H)
5200 - KSPR [MPEG4 HD] moved from EchoStar8 77W TP 17 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Mkt:Springfield, MO-Springfield, MO-ABC) (A) (H)
5201 - KOLR [MPEG4 HD] moved from EchoStar8 77W TP 17 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Mkt:Springfield, MO-Springfield, MO-CBS) (A) (H)
5202 - KYTV [MPEG4 HD] moved from EchoStar8 77W TP 17 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Mkt:Springfield, MO-Springfield, MO-NBC) (A) (H)
5203 - KSFX [MPEG4 HD] moved from EchoStar8 77W TP 17 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Mkt:Springfield, MO-Springfield, MO-FOX) (A) (H)
7224 - KRBK [MPEG4 SD] moved from EchoStar8 77W TP 17 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Mkt:Springfield, MO-Osage Beach, MO-N/A) (A) (H)
7225 - KCZ [MPEG4 SD] moved from EchoStar8 77W TP 17 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Mkt:Springfield, MO-Springfield, MO-CW) (A) (H)
7226 - KOZK [MPEG4 SD] moved from EchoStar8 77W TP 17 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Mkt:Springfield, MO-Springfield, MO-PBS) (A) (H)
5160 - WCPO [MPEG4 HD] moved from EchoStar8 77W TP 04 ConUS beam to EchoStar15 61.5W TP 18 ConUS beam (Mkt:Cincinnati, OH-Cincinnati, OH-ABC) (A) (H)
5161 - WKRC [MPEG4 HD] moved from EchoStar8 77W TP 04 ConUS beam to EchoStar15 61.5W TP 18 ConUS beam (Mkt:Cincinnati, OH-Cincinnati, OH-CBS) (A) (H)
5162 - WLWT [MPEG4 HD] moved from EchoStar8 77W TP 04 ConUS beam to EchoStar15 61.5W TP 18 ConUS beam (Mkt:Cincinnati, OH-Cincinnati, OH-NBC) (A) (H)
5163 - WXIX [MPEG4 HD] moved from EchoStar8 77W TP 04 ConUS beam to EchoStar15 61.5W TP 18 ConUS beam (Mkt:Cincinnati, OH-Newport, KY-FOX) (A) (H)
8354 - WSTR [MPEG4 SD] moved from EchoStar8 77W TP 04 ConUS beam to EchoStar15 61.5W TP 18 ConUS beam (Mkt:Cincinnati, OH-Cincinnati, OH-MY) (A) (H)
5200 - WCHS [MPEG4 HD] moved from EchoStar8 77W TP 08 ConUS beam to Echostar15 61.5W TP 23 ConUS beam (Mkt:Charleston, WV-Charleston, WV-ABC) (A) (H)
5201 - WOWK [MPEG4 HD] moved from EchoStar8 77W TP 08 ConUS beam to Echostar15 61.5W TP 23 ConUS beam (Mkt:Charleston, WV-Huntington, WV-CBS) (A) (H)
5202 - WSAZ [MPEG4 HD] moved from EchoStar8 77W TP 08 ConUS beam to Echostar15 61.5W TP 23 ConUS beam (Mkt:Charleston, WV-Huntington, WV-NBC) (A) (H)
5203 - WVAH [MPEG4 HD] moved from EchoStar8 77W TP 08 ConUS beam to Echostar15 61.5W TP 23 ConUS beam (Mkt:Charleston, WV-Charleston, WV-FOX) (A) (H)
7319 - WQCW [MPEG4 SD] moved from EchoStar8 77W TP 08 ConUS beam to Echostar15 61.5W TP 23 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-CW) (A) (H)
7321 - WPBY [MPEG4 SD] moved from EchoStar8 77W TP 08 ConUS beam to Echostar15 61.5W TP 23 ConUS beam (Mkt:Charleston, WV-Huntington, WV-PBS) (A) (H)
7322 - WOUB [MPEG4 SD] moved from EchoStar8 77W TP 08 ConUS beam to Echostar15 61.5W TP 23 ConUS beam (Mkt:Charleston, WV-Athens, OH-PBS) (A) (H)
7325 - WPBO [MPEG4 SD] moved from EchoStar8 77W TP 20 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-PBS) (A) (H)
6842 - UP11 [MPEG4 HD] moved from EchoStar15 61.5W TP 18 ConUS beam to EchoStar8 77W TP 04 ConUS beam (Virtual Channel) (NA)
6844 - UP11 [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Virtual Channel) (NA)
Transponder Changes:
Nimiq5 72.7W TP 12 ConUS beam 22500 QPSK TURBO CODED 5/6 added
Nimiq5 72.7W TP 18 ConUS beam 22500 QPSK TURBO CODED 5/6 added
EchoStar15 61.5W TP 18 ConUS beam changed from 21500 8PSK 2/3 to 22500 QPSK TURBO CODED 5/6
Echostar15 61.5W TP 23 ConUS beam changed from 20000 QPSK 7/8 to 22500 QPSK TURBO CODED 5/6
EchoStar15 61.5W TP 26 ConUS beam changed from 21500 8PSK 2/3 to 22500 QPSK TURBO CODED 5/6
EchoStar8 77W TP 02 ConUS beam 22500 QPSK TURBO CODED 5/6 added
Channels in the system: 7490
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.10.28
© 2011 - All Rights Reserved - SatelliteGuys Incorporated
D
1/30/2011 8:49am - Uplink Activity Report - 38 changes
D
1/30/2011 10:39am - Uplink Activity Report - 27 changes
Similar threads
D
Replies
Views
2K
D
D
Replies
Views
2K
D
