1/08/2015 10:13 - Uplink Report - 34 Changes
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 1/08/2015 10:13 - 34 Changes
Uplink Comparison Range: 1/08/2015 10:10 - 1/08/2015 10:13 (PST)
MAP Changed:
4971(32) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (32) removed (Dish Network Information Channel)(NA)(H)
4971(32) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (32) removed (Dish Network Information Channel)(NA)(H)
4972(49) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (49) removed (Dish Network Information Channel)(NA)(H)
4972(49) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (49) removed (Dish Network Information Channel)(NA)(H)
4973(15) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (15) removed (Dish Network Information Channel)(NA)(H)
4973(15) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (15) removed (Dish Network Information Channel)(NA)(H)
4974(38) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (38) removed (Dish Network Information Channel)(NA)(H)
4974(38) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (38) removed (Dish Network Information Channel)(NA)(H)
4975(5) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4975(5) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4976(6) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4976(6) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4977(15) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (15) removed (Dish Network Information Channel)(NA)(H)
4977(15) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (15) removed (Dish Network Information Channel)(NA)(H)
4978(61) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (61) removed (Dish Network Information Channel)(NA)(H)
4978(61) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (61) removed (Dish Network Information Channel)(NA)(H)
4979(62) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (62) removed (Dish Network Information Channel)(NA)(H)
4979(62) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (62) removed (Dish Network Information Channel)(NA)(H)
4980(49) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (49) removed (Dish Network Information Channel)(NA)(H)
4980(49) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (49) removed (Dish Network Information Channel)(NA)(H)
4981(64) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (64) removed (Dish Network Information Channel)(NA)(H)
4981(64) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (64) removed (Dish Network Information Channel)(NA)(H)
4982(25) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (25) removed (Dish Network Information Channel)(NA)(H)
4982(25) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (25) removed (Dish Network Information Channel)(NA)(H)
4983(20) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
4983(20) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
4984(48) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (48) removed (Dish Network Information Channel)(NA)(H)
4984(48) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (48) removed (Dish Network Information Channel)(NA)(H)
4985(56) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (56) removed (Dish Network Information Channel)(NA)(H)
4985(56) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (56) removed (Dish Network Information Channel)(NA)(H)
4995(53) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (53) removed (Dish Network Information Channel)(NA)(H)
4995(53) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (53) removed (Dish Network Information Channel)(NA)(H)
4998(3) - LOCAL [MPEG2 SD] EchoStar14 119W TP 21 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4998(3) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
Channels in the system: 9523
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
1/08/2015 08:53 - Uplink Report - 1 Change
1/08/2015 09:12 - Uplink Report - 2 Changes
