1/05/2016 15:56 - Uplink Report - 23 Changes
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 1/05/2016 15:56 - 23 Changes
Uplink Comparison Range: 1/05/2016 15:49 - 1/05/2016 15:56 (PST)
MAP Changed:
5816 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (2) added (LOCAL)(Mkt: Lafayette,LA)(NA)(H)
5816 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (2) added (LOCAL)(Mkt: Lafayette,LA)(NA)(H)
5817 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (3) added (LOCAL)(Mkt: Butte,MT)(NA)(H)
5817 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (3) added (LOCAL)(Mkt: Butte,MT)(NA)(H)
5818 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (6) added (LOCAL)(Mkt: Colorado Springs,CO)(NA)(H)
5818 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (6) added (LOCAL)(Mkt: Colorado Springs,CO)(NA)(H)
5819 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (9) added (LOCAL)(Mkt: Missoula,MT)(NA)(H)
5819 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (9) added (LOCAL)(Mkt: Missoula,MT)(NA)(H)
5820 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (7) added (LOCAL)(Mkt: Corpus Christi,TX)(NA)(H)
5820 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (7) added (LOCAL)(Mkt: Corpus Christi,TX)(NA)(H)
5821 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (4) added (LOCAL)(Mkt: Great Falls,MT)(NA)(H)
5821 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (4) added (LOCAL)(Mkt: Great Falls,MT)(NA)(H)
5822 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (7) added (LOCAL)(Mkt: Santa Barbara,CA)(NA)(H)
5822 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (7) added (LOCAL)(Mkt: Santa Barbara,CA)(NA)(H)
5823 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (3) added (LOCAL)(Mkt: Billings,MT)(NA)(H)
5823 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (3) added (LOCAL)(Mkt: Billings,MT)(NA)(H)
5824 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (5) added (LOCAL)(Mkt: Tucson,AZ)(NA)(H)
5824 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (5) added (LOCAL)(Mkt: Tucson,AZ)(NA)(H)
5825 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (26) added (LOCAL)(Mkt: Helena,MT)(NA)(H)
5825 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (26) added (LOCAL)(Mkt: Helena,MT)(NA)(H)
5826 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , map (19) added (LOCAL)(Mkt: Lexington,KY)(NA)(H)
5826 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , map (19) added (LOCAL)(Mkt: Lexington,KY)(NA)(H)
Channel Moves:
5280(12) - KATC [MPEG4 HD] Echostar16 61.5W TP 28 Spotbeam 40 renamed to LOCAL , moved to Echostar16 61.5W TP 08 Conus (LOCAL)(Mkt: Lake Charles,LA)(A)(H)
Transponder Changes:
Echostar16 61.5W TP 08 Conus (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 28 Spotbeam 40 (21.500 8PSK 2/3) removed.
Channels in the system: 9802
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
1/05/2016 23:40 - Uplink Report - 2 Changes
1/07/2016 03:15 - Uplink Report - 2 Changes
