HipKat please let us know anything that comes from the portal today thanks
Have you tried a check switch and then a pull the chord reset. Then try the Update Software tool again.Two days in a row I woke up to turn my tv on around 3 am and it has been downloading Vital nformation to my receiver. When it finishes I'm still stuck on U527 software and trying to use the tool to make it update just says your software is up to date and current.
At least you are not getting random "downloads of vital information" throughout the day even though your receiver is set to do that at 3AM. I experienced one this morning at 7:42.Two days in a row I woke up to turn my tv on around 3 am and it has been downloading Vital nformation to my receiver.
I'll try that later today.Have you tried a check switch and then a pull the chord reset. Then try the Update Software tool again.
If the tool lets you download, here has been my experience doing the download if it helps.I'll try that later today.
Thanks for the reply. Disclaimer, I know little to nothing about MOCA. The new receiver (528) under Details shows green arrows with values both up and down, under Summary is shows Discovered Unlinked. The older receiver (527) shows yellow arrows both up and down with question marks in the numbers columns. It also shows Discovered Unlinked. Like I said, I really don't know what this means.
I have considered trying to update the older receiver to 528, will probably try this afternoon.
The Hopper3 receiver with the yellow arrows with question marks is not connecting correctly to the other Hopper3 receiver over moca. I had a similar problem when my two Hopper3 receivers were initially installed. The Dish installer hooked them up wrong and I could only receive but not send over the moca connection. Dish ended up replacing my one Hopper3 receiver.
Both Hopper3 receivers should show green up and down arrows. It should show the Receive Mbps and Send Mbps > 200. Both Receive and Send Errors should be 0. My Signal to noise ratio is 41 but I am not sure what an acceptable value is.
Just got off the phone with Dish. You're correct, the Hopper3 is toast. That's both of them in a week. They are sending me a replacement. She said there's a chance I can recover the recordings from the bad receiver but since I can't access them now, which she thought would work its not looking good. Very odd since nothing has changed in a year and a half.
As I understand it they are connected via MOCA. But it seems that was a problem. There is a jumper between the two switches ( I think they're called duo switches). We tried disconnecting the sat feed to the receiver but that didn't fix the problem. Depending on where in the cycle its in you catch it sometimes the new software version shows in the status screen, other times the whole thing save the remote info is blank. The Dish tech said there is a remote chance it will recover during the nightly update but she didn't sound very optimistic.
