well, make sure the combination of ladder and gravity doesn't take care of it before your wife doesmy wife would kill me .if she knew i was up this high. View attachment 131484
Yeah no doubt!!! dl76 Dude that ladder is inside out! turn it around!well, make sure the combination of ladder and gravity doesn't take care of it before your wife does![]()
Well my extension ladder must have been built back wards. The way i had it set up in picture . The rope is out facing towards me.You can't raise/lower the extension when its backward. Most ladder rungs have a flattened surface when turned the correct way. The brackets are not designed to handle stress from that direction. Probably more reasons I can't think of right now.
No, the rope is supposed to be on the inside.Well my extension ladder must have been built back wards. The way i had it set up in picture . The rope is out facing towards me.
I will get picture tomorrow of trees around me. If the rope is on inside of ladder rungs. I would have to reach through rungs to pull up. Anyways have a great evening guys.No, the rope is supposed to be on the inside.
I can't see if you have tall trees around you or not, but it looks like you could drop it down 3-4 feet and be able to work on it more easily.
You stand facing the right side and pull the rope with your right hand and pull the ladder up with your left. If you are left-handed - face the left side and reverse hands.I will get picture tomorrow of trees around me. If the rope is on inside of ladder rungs. I would have to reach through rungs to pull up. Anyways have a great evening guys.
Will check it tomorrow in sunlight. Maybe this ladder rope has been replaced wrong.You stand facing the right side and pull the rope with your right hand and pull the ladder up with your left. If you are left-handed - face the left side and reverse hands.
