http://about.att.com/story/watch_it...are&siteId=lw9MynSeamY-_xiwJ8_RQk5gFy03YIVuvg
This is very good news
I heard that if you use your iPhone as a hot spot to stream directv on a wi-fi only iPad, that will not be free data? Can anyone confirm this?
Sent from my iPhone using SatelliteGuys mobile app
But you don't need the unlimited data plan to get the unmetered streaming of DIRECTV content.I cannot say for certain but I doubt it is allowed. Mobile hotspot is not included in the unlimited data plan so I would imagine that's the case here.
Sent from my iPhone
Not according to this press release, http://about.att.com/story/watch_it_anywhere_with_att_directv.html. Wouldn't make sense to tell people that you can stream DIRECTV content via cellular data but if you hit a limit you can't. What you say is true for regular data usage, not this new service.But if you go over your allotted data whether it be 15 megs or unlimited which is technically 22 I believe, AT&T will throttle your data and you will not have access to DirecTV streaming. I read this somewhere in the last couple days. I'll see if I can find it
Sent from my iPhone
I turned on the hot spot on my iPhone and the connected my iPad to there so I was using cellular. Started up a streaming session and let it run for a while. I then looked at my AT&T account and the usage for regular data stayed the same but the usage for the sponsored data went up. So yes you can use a WiFi only iPad via a iPhone hotspot to stream DIRECTV and not have it go against your data usage.
Sent from my iPhone
I found it FINALLY......
https://support.directv.com/app/answers/detail/a_id/4740
Yes but in a different way, when I look at my usage it "Sponsored Data", at least it was generated once I started using the new DIRECTV app for streaming.Has anyone seen this "Bonus data" from AT&T. Apparently I received it because I used Data Free TV....Anyone have anymore details on this??
