In a few days I'll have a new meter and it will be time to finally get my dishes in proper working order.
The trees are gone so now it's only a matter of me aligning them properly, no more "Oh woe is me, trees in the way!"
I switched out the LNBF in my 10' dish the other day and in the process, I noticed that the skew markings on the backs of the two of them are different. See the attached image below.
Anyway. Let's play C-band for dipsticks for a minute. After several years of thrashing about like I'm drowning in the ocean I have come to realize that it's just a puddle and I'm not drowning. Time to stop thrashing about, calm down and call for help..
In my drawing here, let us say that I am standing in front of the dish facing it.
(big circle is the dish, the little circle in the middle is the LNBF)
Inside the LNBF there are two little wires that I believe are the horizontal and vertical antennas. Yes?
Should the LNBF be mounted so that the vertical antenna is perfectly plumb, in alignment with the big metal bar in the back that the dish pivots side to side on? I don't know what that part if called.
If I tip the dish all the way forward so that it's vertical, that big square bar is also vertical.
Now if the LNBF is aligned so that it's little antenna inside is perfectly vertical, that would mean that the horizontal antenna would be either at the 3 or 9 o'clock position depending on where the horizontal goes, does it go at 12 or 6 o'clock? Um, or maybe my drawing is all wrong.
I noticed that inside the LNBF there is a thick metal rod which is a mystery to me but it seems to be in all the C-band LNBF's that I have so I guess it's legit. Do I line this rod up so that it's perfectly vertical?
Is it true that the skew is changed by the dish pivoting around the arc?
Once I get the LNBF mystery figured out then I would like to move on to setting the elevation.
I don't want to jump ahead because I'll get everything all mixed up and start thrashing around in the puddle again.
I THINK I more or less know the steps to align an HH motorized KU dish but this is obviously more complicated. I've never gotten my 10' dish to work right, it's not on the arc and out of frustration I parked it on 101 for MeTV and have left it there.
Also, once I get my 10' dish in proper working order I want to see if you guys can walk me through building a 6' mini-bud.
Thanks! :
Thanks! :
