Hi gang. My first post and I hate it when the first one is asking for help, but here I go:
5-6 years ago I installed a DTV system myself consisting of the following:
Antenna with a single dual LNB
3 D12 receivers
Sonora Stacker sending signal to the 3 D12's
Sonora unstacker feeding R22/100 DVR
1 of the D12's spends some time as an RV unit and some time as a garage unit functioning as an SD setup
I have moved into the 21st century with a 60' flat screen and want to convert to HD on only a couple of outlets.
I have not had good luck with getting info from DirectTv- I think I will have better luck here.
Signal enters the house through 1 coax. There can be only 1 coax- it is buried- the dish is 150' from the house. Signal splits to the 3 inside locations. The worst has signal strength on 101 between 69 and 95- this is after unstacking at the R22. The rest are 85-97 across the transponder list.
Here is what I want to do and I need equipment suggestions:
2 units HD- I believe the R22 will handle 1. These are permanent installs.
1 unit SD permanent installs
1 unit SD RV/Garage install using existing SD dish.
Is this configuration possible with my setup? What is the best way to deal with the dish signal coming inside? What receivers do I need to add?
Thanks for your help!
3 D12 receivers
