opinions
Seemed like most of the comments were negative, while the voting was more distributed.
Maybe we should hear from more of the folks who like/use the display, and why/how.
Or, maybe my bias filter just appreciated the negative comments more.
My big HD TV has a blue LED that's on for AC power, and off when you power up the set.
That's actually fine for a TV.
My little HD TV has an orange LED for AC power, and it goes blue when you power up the set.
I appreciate the color change to let you know it's still alive, and the blue LED is -not- blinding.
My DVD player has a red LED for AC power, and goes off when you power it up.
Of course, the white alpha-numeric display comes on showing words to let you know what it's doing.
Even though I can't read the white display across the room, it's comforting to see the red LED change state when I hit the remote.
My external OTA dual tuner is a Silicon digital HD HomeRun
If plugged in, it's powered. No switch.
It has a green power LED far to the left. (always on)
Centrally located behind a black-out panel are three more equally spaced green LEDs.
Left-most is a LAN-active lite (should be on if plugged into network - doesn't blink)
The right two come on if their respective tuner is being accessed.
From across the room, it's impossible to tell which green LEDs are lit; the LAN LED should have been orange.
For a Satellite Receiver:
I'd say that some LEDs would be sufficient.
Can't see display from across the room, anyway.
Power LED, orange/red when Off, and blue/green when On (blank only when unplugged)
IR LED which blinks when receiving a signal from the remote control (could be double duty with power LED)
Scan LED, which comes on when blind scanning, and blinks when a live transponder is found. (yellow?)
Recording LED, which comes on when recording to the hard drive, if feature is available. (red?)
HD LED, on if tuned to a high def signal. (low priority)
S2 LED, on if tuned to an S2 signal. (low priority)
LEDs should be well spaced and different colors so you can tell which is which from across the room.
Maybe an alternative alpha display could be fitted to one wide cutout in the case front, and covered with a smoky screen.
Introduce the high end model first, and a few months later offer the lower priced LED-only model.
Sell the alpha numeric panel as an option so if I buy a used LED model, I can upgrade it.
Product naming:
Pansats are 2500, 2800, 3500, 9000, 9200. Easy names, simple, and clear.
Viewsats have multiple annoying words to denote the model; I have one, and still can't remember which it is.
AZboxes are an example of poor naming.
I realize "HD", "PVR", and "S2" might be meaningful in a name, but keeping it simple has its own elegance.
Product naming:
