I have a customer that I installed an OTA tuner in a 722 for and all their guide will show is an 8 hour block " digital programing " it knows what the stations are but not what's playing.
Just an update on my situation. I had my 722K replaced last week because my old one had an overheating problem. Not only does the new one have the same problem with OTA timers, it's worse! It doesn't even record things if I set it to "once". On Saturday I set it to record the F1 race on Fox on Sunday afternoon. It showed up in my schedule and everything looked good. Sunday morning I checked the schedule and it wasn't there. Not skipped or anything, just not there, though the timer was still there on the list. Same thing happened later in the evening when I tried to record Big Brother for my wife. So the only way I can record anything OTA is to wait until it's actually on then hit "Record".
Guess it's time to bug Dish again.....![]()
From what I can gather, the problem only exists for people who subscribe to local channels through Dish. When you pick a program, i.e., CSI NY for 10pm on Wed and set it to record all episodes or new episodes. Somehow when it does the search, it doesn't find the ones besides the one you selected. So it'll know to record CSI New York for this week since that's the one you selected, but nothing in the future.
The issue only appears to affect CBS-01, ABC-01, NBC-01, and FOX-01. I deduced that this is due to the fact that Dish only supplies the big4 stations' HDs. I tried setting a similar recording on the local OTA CW-01 and it works fine. The reason being that CW-00 HD doesn't exist via Dish. Somehow it appears to be treating the -01s as being redundant. It sees the Dish supplied -00 HD and it disregards the -01 OTA HD results.
I spoke to dish reps about 5 days ago and they said it was escalated to the engineers and they are working on the issue. It does appear that they had an update a few weeks ago and that's when it started having an issue. I checked today and it still is not resolved. Hopefully they fix the problem before the fall season. Not that big of an issue for me right now as the summer season is slow.
You should prioritize your timers and set them on -00 HD instead of the OTA-01. Anything on -02 HD seems to work fine, by the way. Anything that you set weekly, M-F, or once should work fine. I wouldn't set anything OTA-01 using the all episodes/new episodes until the problem is resolved. I'd try it and check to see if it sees beyond the one you set.
Hope all that makes sense. Good luck!
I should mention that I only have this problem on ABC, NBC, CBS and FOX. Those channels I also receive from Dish.
I have no problems recording "All" or "Once" or "New" on channels I do not also receive from Dish (PBS, CW, etc).
Its almost like Dish is trying to force us to use the channels they broadcast.
It's been a while, has anyone heard anything new on this?
I thought I had the problem fixed by scheduling the show to record twice, first on the xxx-01 channel, then on the xxx-00 SAT channel. Problem is the 2nd timer thinks the first one will record it, so it skips, then the first one doesn't. Very annoying and have not found a real workaround on this yet.
Also, I never had an issue with this until the new software that allowed the grouping.
I just started having the same issues as others in this thread.
I have two VIP622 receivers and now none of the OTA timers I have set are firing. I have deleted the timers and reprogrammed them. I go into the guide and reset the timers and they show up in the schedule and Timers list. After a few hours or overnight the scheduled recordings just disappear. I still show the timer on the timer list but when I click on the timer it shows no episodes to record. This has to be an issue with L622. I never had an issue before this SW release. I spoke to E* support and they said they will look into it and they hope they will have a fix in 24 hours.
Do you have a 1000+ dish? I disconnected 118 and the OTA timers started to work normal. See my post #34
Do you still get the the local HD channels from Dish?
Yes, I still get the HD local channels from Dish. My OTA timers for ABC, CBS, and NBC started acting up last May. I called Dish about it several times with no results. I found out from another member from another forum from the St Louis area that by disconnecting 118 the OTA timers would work properly.
