Greetings oh geniuses of the Dish Network Technical Forum
I have been having some minor but annoying issues with signal loss that I was hoping to get some help with.
Let me first let you know what my setup is:
622 in the basement hooked up Component to the TV there. Then I have the TV1 mirrored HDMI to a TV upstairs. We don't normally watch TV both upstairs and downstairs at the same time, so it is nice to have the same DVR'ed shows available in HD in both spots.
Anyhoo, in the past couple of months or so we have been noticing a few scheduled shows not recording. When I look to see what happened it will say Skipped and No Signal for the reason. Also many times when we tune to an HD channel (most frequently HD locals, HGTV HD, and TLC HD) it will not come up and then after a few seconds it will go to the searching for satellite. Sometimes that comes back but more often when it does that it will go to the message that tells you to change the channel and it won't come back for a good while. Pretty annoying.
So Friday, I called Dish when it was doing this and they had me do a Check Switch and it came back with the warning screen where it says something like you have less satellites than before, do you want to continue. (I have done check switches before when I have the issue and it is normally fine) They suggested that I might have an issue with cabling and wanted to send a tech out.
Ok, so the tech came out and he could not get past my setup of the 2 HD TVs mirrored on TV1. NO matter what I said he just did not understand the issue I was having. He kept thinking that my upstairs TV was hooked on TV2 and that was why I was having issues getting HD channels… I said, but I have one TV hooked up HDMI and one hooked up component, how could that be on TV2? And he says, no that is not how it is hooked up… But I am getting most channels, just not all of them...
Argh. He was a super nice guy, so then I gave up on him and we just chatted while he did the paperwork and I mentioned the 922. He had not heard of it. Strange that I know what is coming up before the tech does…
So after all that I am back where I started. My questions for you guys are:
Any idea what could be the issue?
What signal strengths are good to best on each satellite? The tech on the phone mentioned something about low signal on only some transponders. How can I find out if that is the case and how can I make that better?
