Disconnect the sat inputs from the back of the receiver. Run a check switch (it'll take about 8-10 minutes).
Reconnect the sat inputs to the back of the receiver and run a check switch again. It should go through all 38 at the "normal" rate.
If it works, everything should be fine when it's complete.
Hope that helps.
Well I came home for lunch and turned the tuner on to try and do the switch matrix reset and the tuner was working. So now should I wait until it goes out again or should I go ahead and reset it now?
I just hope I can duplicate the problem when the tech comes out to my house on Thursday. I will be doing the reset tonight.
I had a brief outage on 119 TP 6 in the early morning hours like 2-4a for a minute or two. Totally lost lock. It came right back though.
Well nothing has worked for me. I finally got a call back from my local retailer. Seems they lost my service request from a week ago. So now, I told them what's happening. That I keep losing 129, and that the signal on 110 & 119 are at 51. However, on my 311 in the other room, the signal for 110 & 119 are 98. So dish is now telling them that I probably have a defective 722, and that I will need to RMA it. I've had this thing for a little over a week! Ghheshh!!!![]()
ok, then that's a different issue. But I still say your 722 is fine and doesn't need rma'd.
