I had ordered two more HDVR GeoSatPro 1200s and canceled the order when I discovered that the owners manual installation guide did not cover any steps to use these other two receivers for advanced operation for other satellites, other than GloryStar ,but I could get technical advise for advanced settings from Eugene @ GloryStar for 25.00 over the phone.
My problem is I have ADHD and do not retain a given sentence, but I NEED something in writing to read over and over again, until all the tid bits start coming together.
I even asked for hand written notes on the advanced operation, like their customer service would use to answer the phone questions.
Meanwhile, my first 1200 is resting on GloryStar ,which is great.
Dear Alemmoe,
First, I would like to apologize for not providing detailed guide in print. Unfortunately, the person responsible for it quit not finishing the project. I will update the guide with hobby functions shortly.
Second, we do not charge $25.00 I have never charged 25.00 for HDVR1200. Because, this is not your fault I didn't provide you with instructions. Also, our advanced support for one year is $19.99 for other products. We have customers that really rely on our help on a daily basis years after they have purchased the equipment and we have the support available for them. We have been helping all clients with all level of complexity at no cost for the last two years.
Alemmoe, here are basic instructions that will help you setup GEOSATpro HDVR1200 in advanced hobbyist mode:
If the receiver has been setup in Glorystar mode, go to Menu > Settings > Factory Setting and do a factory reset.
Once the receiver is in initial startup mode, where it asks Glorystar or Advanced, click right arrow on the remote to select ADVANCED with Red X on it then press OK button.
To select desired satellites, press Menu > Satellite Setup and go through all satellites you want to watch using your motor or if fixed dish, just select the satellite you will use by highlighting it in the list, then pressing OK button. That creates a Red Check Mark on the left side.
After you selected a satellite, press the right arrow key and set the LNBF LO frequency and go to the Motor type and select USALS or DiSeCq 1.2. Then press ok and it will take you to the Motor (Positioner) setup, where for USALS you have to enter your Latitude and Longitude. It is important the settings to be correct.
If you are Using DiSeCq, please use preprogrammed positions in the motor first, then manually move the motor to the desired satellite and store it's position.
Let me know if you any additional advanced help. This is of course as basic as it gets.
Eugene
SatelliteAV
