my first day playing around with a mini-bud....only had a few hours but was actually more successful than i expected....my setup is a 39 inch dish with SG9120 motor with an invacom LNB....
i started by peaking in the signal for 91w ku-band and saved the position....then i shut it all off and swapped the LNB for a DMX-241 c-band and conical scaler ring....i removed the plastic end cap from the lnb and taped a zip-lock bag around the lnb to prevent water damage....i hoped this might add a bit signal quality....
started by moving the lnb in and out and the ring in and out to see the best reading i could get which was about 25Q (using a viewsat ultra) which is enough to lock on this receiver....i then removed the conical scaler ring completely and the quality stayed the same with it off....i installed the flat scaler ring and the quality went up a bit to about 35Q....
the weather was very cloudy so who knows maybe i could even do better on a clear day....i was able to get a few TPs from 91w and a few from 99W at about 35-40Q which is more than enough to watch without any pixelation....
i have not adjusted the vertical dish setting yet, i only adjusted horizontally with the motor....so im not sure if that is peaked or not but seems pretty good when im using it for ku....
all in all i think its a good start for only a couple hours work....i have attached some pics of the dish and tv screenshots....one of 91w and one of 99w....
