Inspired by recent efforts by turbosat and mikelib I decided to see what I could get with a Dish 300 (18" x 20") oufitted with a WSI DMX521 linear LNBF on a SG2100 motor. Receiver was a Coolsat 6000.
First mounted the motor on the pole and installed the dish (with circ LNBF) on the motor. I moved the dish pivot point to another existing hole in the stock bracketry, but in hindsight I don't think that was necessary.
Set the motor latitude to 37, eyeball-aimed it to 93W (TS, true south) and swagged the 48 degree elevation with my dig angle finder.
Sent the dish to 110W using USALS, did a little az/el tweaking and quickly had circ signal, then did the same at 119W. I didn't find any circ east of my TS (Mpeg-4?) but didn't try too hard.
At that point I thought I was kinda on the arc so I motored back to TS @93W, took some location measurements off the circ LNBF and installed the DMX521.
Started looking for the Azteca mux on 93W and it took me quite a while. I truly learned the difference in aiming accuracy required for DBS vs. DVB on a tiny dish like this....2 different worlds.
Long story short, I finally got the Azteca mux locked and viewed and started going east and west, making very small az/el adjustments as I went.
I didn't write down my SQ readings, but off the top of my head can say I had no trouble viewing the NBC mux on 72W, ONN @ 74W, NYN @ 79W, Echo test @ 85W, lots of stuff on 97W, CGN, BVN, 3ABN (@ 93%-94%!) on 101W and Montana PBS on 125W. All of those were a minimum of 69%-70%, which is a solid pic on a CS6K, several were in the 87%-88% range.
It was a fun project and just goes to show what you can get with a tiny dish like this (heck, anybody can get stuff with one of those massive Dish 500s ), with some tweaking.
I honestly did not play with the LNBF position much after the initial placement, but it is very close to where the factory location was, and aimed at the same spot on the dish, so I'm not sure how much more that would have given me.
