broke off from another thread
I bought one and just installed it today. It works....um how you say...um
AWESOME!!
Now it will ONLY work if your receiver does Diseqc 1.1
It will not work with Diseqc 1.2 (been there tried that). The receiver MUST support Diseqc 1.1
Hooked it up to my Visionsat...and now have 11 LNB's on it
port 1 is 74
port 2 has a 4x1 diseqc switch on it. Port 1-4 is 72,79,85,89
port 3 is 119
port 4 is 123
port 5 is 99C Band
port 6 is 93
port 7 is 97
port 8 is 101
setup is a breeze. For all ports but 2 (since it has a switch attached) you just set it up as port 1,3,4,5,6,7,8 as uncommitted (there are 16 spots)
port 2 is weird but easy...on those 4 LNB's just set uncommitted to port 2 and the committed like a regular diseqc depending on which port its on
so set up is (diseqc 1.0/diseqc 1.1)
74 X 1
72 1 2
79 2 2
85 3 2
89 4 2
119 X 3
123 X 4
99 X 5
93 X 6
97 X 7
101 X 8
The "X" means I don't set the diseqc 1.0
This switch looks promising;
"Digiwave Brand SW81 8x1 DiSEqC Switch 8 in 1 switch".
8 ports all uncommited. Uncommited switch 1,2,3,4,5,6,7,8.
about $20 shipped
If the switch works good then, we will have to ask Anole to update the Diagram for "32 satellites on one diseqc switch". he he he (mad scientist laugh)
a uncommitted diseqc switch can be cascaded in front of the standard (committed) diseqc switches for 32 ports. If you add tone switches (or multiswitches) then 64 ports, If you add band stacked LNB's, then you have 128 ports.
AWESOME!!
port 1 is 74
port 3 is 119
port 4 is 123
port 5 is 99C Band
port 6 is 93
port 7 is 97
port 8 is 101
74 X 1
72 1 2
79 2 2
85 3 2
89 4 2
119 X 3
123 X 4
99 X 5
93 X 6
97 X 7
101 X 8
